Field conditionnal visibility
Hi all,
In a simple form, I’d like a field “B” to appear if the value for field “A” is equal to ‘Other’.
I’ve seen I few posts about a conditionnal visibility parameter but I can’t find the options in my configuration tab. I can only set the widget type to hidden.
NB : QGIS 4.2.3 / QField 4.3.3
Hi! You need to put the field B inside a sort of container. Then the container will give you the option to control its visibility using an expression. Check this video tutorial (starting at minute 2:43 I think is where the part that would interest you the most does begin) to see an example. there the teacher creates a “tab” on the Drag 'n Drop Designer, drags the attribute name inside it, clicks on the tab name and on the right you can see an option Control Visibility by Expression (disabled by default).
Hi @cuprico simple and effective, thank you!
