How to get Lat/Long from Emlid Flow App into Qfeild app via Bluetooth?
  1. Is there any SDK available to connect my app with Emlid Flow via Bluetooth or Wi-Fi to retrieve the Emlid device’s latitude and longitude and display the location on our mobile app map?
    2.Does the Emlid Flow app broadcast NMEA or JSON messages over Bluetooth so that external apps can receive them?
    3.If not, should I connect my app directly to the Reach device (bypassing Flow) to read NMEA sentences via Bluetooth SPP? or having any SDK to Connect with my apps and Emlid Flow app
    4.Is there any recommended approach or API to access position data while using Flow app simultaneously?
Try using our GeoLink app. You can find it in the Google Play Store at the following link:
The app is currently still under development. We have not yet tested it with EMLID devices.
Please send me the device name with which your antenna is displayed in the Android Bluetooth settings to info@feelgood-gs.de. I will then send you detailed instructions on how to configure the app for your antenna.
