I’m currently writing a little project plugin for QFIELD that creates a toolbar button with an SVG icon using the following code:
QfToolButton {
bgcolor: Theme.darkGraySemiOpaque
width: 40
height: 40
padding: 0
round: true
iconSource: "update.svg"
This works perfectly fine, but to avoid a separate SVG file for the icon in the project folder, I’m trying to embedd the SVG via data source uri directly into the plugin code :
QfToolButton {
width: 40
height: 40
padding: 0
round: true
iconSource: 'data:image/svg+xml;utf8,<svg fill="#000000" width="800px" height="800px" viewBox="0 0 24 24" xmlns="http://www.w3.org/2000/svg" id="update" class="icon glyph"><path d="M5,12A7,7,0,0,1,16.89,7H14a1,1,0,0,0,0,2h5.08A1,1,0,0,0,20,8V3a1,1,0,0,0-2,0V5.32A9,9,0,0,0,3,12a1,1,0,0,0,2,0Z"></path><path d="M20,11a1,1,0,0,0-1,1A7,7,0,0,1,7.11,17H10a1,1,0,0,0,0-2H4.92A1,1,0,0,0,4,16v5a1,1,0,0,0,2,0V18.68A9,9,0,0,0,21,12,1,1,0,0,0,20,11Z"></path></svg>'
This works as intended, however the SVG icon appears pixelated and blurry. What am I doing wrong or do I have to set some sort of scaling factor to it? When I use a web uri of the same icon (svgrepo.com/show/460134/update.svg), it is rendered nicely. But as I want this to be offline useable, this is not an option.
