I use QField in the field and usually perform my delineations using the tracking feature.
I create a LineString layer called “Track” in my QGIS project and then import the project into QField. In the field, I long-press the layer, select"Tracking settings", then"Start tracking". After entering the attribute information and confirming the form, QField displays the message:
“Tracking of layer Track started.”
Normally, as I move, a line is drawn behind my GPS position and, when I stop tracking, a new feature is created in the layer.
However, during my last field survey, and again today while testing on a different project, the behaviour is different. Tracking appears to start normally, but:
- no line is displayed behind my GPS cursor while moving;
- no feature is created when I stop tracking.
Additional information:
- QField version: 4.3.0 Danube
- Device: Samsung Galaxy S23 Ultra
- Internal GPS
- GPS positioning works correctly and the position cursor follows my movement
- I can manually create features in the layer
- The tracking layer is stored in a GeoPackage
- The same workflow worked correctly before the latest update
- Distance and time requirements are disabled, exactly as they were when tracking used to work
- The issue occurs on multiple projects
Has anyone experienced the same issue or identified a workaround?
Thanks.
