Hi QField community ![]()
I am investigating methods of entering data without interacting with the mobile device’s screen, and I wonder if anyone had experience of this? I already use the volume buttons for data entry, but it won’t work for my use case.
My use case is recording bird flight height data. The surveyors need to keep their eyes on the bird in flight (with binoculars), otherwise they risk losing it and, therefore, data. For tracking time, we use an interval timer attached to the binoculars that can be started/stopped easily with one finger (e.g. while wearing gloves). This works well for recording the flight duration and number of 15-second intervals in the flight, but not the amount of intervals (time) that the bird flew at each height band. The surveyor usually relies on memory to record height data at the end of the flight (after drawing the flight path), by counting the number of intervals where the bird was flying at various height bands. This is expecially challanging to obtain an accurate count for long flights.
If we could easily record either the elapsed time in each height band, or the number of intervals at each height band, then:
- the workflow would be much more efficient, as the time consuming aspect of recording the flight in QField is entering height data; and
- the data would be more accurate, as it doesn’t depend on the surveyors memory.
I’m thinking, therefore, that a device with a button for each height band could be used like a mutually exclusive bank of timers, perhaps in combination with a QML widget that also provides large touchscreen buttons for each height band.
So, my question is: would it be possible to use a bluetooth keypad/controller/etc and map buttons to certain functions in the QField interface (or inside a QML widget).
For example, the workflow might be:
- the surveyor has a form for the ‘timer’ layer open, ready for the next target bird to flight through the survey area.
- upon spotting the bird, they press the button corresponding with the height band that the bird is flight within. A timer begins.
- when the bird changes height band, the surveyor presses the relevant height band button, which records an height change event associated with that height band.
- this continues until the end of the flight, when the surveyor presses the ‘stop’ button.
- total flight duration and total duration within each height band are displayed for the user to enter after recording the flight line.
Cheers,
