Hi All,
I have paired by Bad Elf GPS/GNSS to my iPad, but I can’t add it to QField in the settings. The app states only ‘Internal device’ and when I try to ‘add’ and ‘scan for nearby devices’ it’s not recognised and I can’t add it. This device is NMEA enabled but still doesn’t register if I try. Any advice?
@Tim_Cadman , does the device support Bluetooth low energy ? Do you have specs you can share ?
These are the only specs I could find - do they help? It is a Bad Elf Flex mini standard.
What do you think?
Tim
Interfaces
- USB: USB device via USB-C receptacle
- Bluetooth: Bluetooth V4.0 (HS) with integrated Class 1.5 PA Supports 3 simultaneous connections
Compatibility
- Operating system: iOS, Android, Windows
- Mobile App: The Bad Elf Flex App requires iOS 9.0+ or Android 9+
- Connectivity: Bluetooth SPP, USB Serial
Operating Specifications
- Operating: –4°F to +145°F (–20°C to +63°C)
- Charging: 41F to +113°F (5°C to +45°C)
Environmental Specifications
- Waterproof: IP67
- Humidity: 5% to 95% non-condensing
Mechanical Specifications
- Dimensions: 1.8” x 1.27” x 3.6” / 45.7mm x 32.5mm x 91mm
- Weight: 5 oz / 143 g
- Enclosure: Polycarbonate
- Mounting: Bottom mount with 1/4”-20 thread
Battery Specifications
- Bluetooth connected/logging: 24 hours
Product Specifications
- USB Port: USB-C port for charging and ElfPort™ expansion
- Accelerometer: 3-axis
- Display: 128 x 128 pixel transflective LCD screen with backlight
- Firmware: Field upgradeable via app or USB
@Tim_Cadman , it doesn’t seem like BLE is supported. On iOS, the operating system doesn’t allow for classic Bluetooth connections, it requires a Bluetooth Low Energy (BLE) connection.
Dear Mathieu,
Thank you. Is this also the same for Garmin? And does this also apply to QFiled?
Tim
@Tim_Cadman , iOS simply won’t permit classic Bluetooth connection to any devices, it’s not vendor-specific. It applies to all apps too.
QField does support classic Bluetooth connection on Android (Windows and Linux OSes as well).
Thanks Mathieu,
I really appreciate your help. I am not entirely sure that iOS doesn’t support Bluetooth (respect). Previously using Avenza (before it went s**t), I was able to link my phone and pad to a single Garmin, and get the same coordinates, at around 3 metres on a good day (clear sky, no wind, not under canopy, etc.), 5-10 on a bad. Doing the same using QField offline. I get 6 m on my phone and 5 m on my pad. Any thoughts?
Tim
