Hello everyone,
I would like to know if there is a possibility of calculating the number of entities collected over a day on qfield without having to go through the computer and Qgis and without having to count everything manually.
I thank you in advance
Imported from GitHub discussion by @Jipforester on 2025-02-19T08:01:39Z
Do you have one or multiple layer ?
A one layer solution can be :
- Create a field called
creation_date
with a default value using the expression: : format_date(now(),'ddMMyyyy')
- Create another field called ‘count_today’ with default value :
count("creation_date", filter:="creation_date" = format_date(now(),'ddMMyyyy'))
- Setting fields properties (non editable, not null, auto update, …)
- Add
count_today
to the form
Each time you add a feature, number of feature added today is printed.
Imported from GitHub comment by @paul-carteron on 2025-02-20T09:51:36Z
Good evening,
I have one layer with the field information.
I tried your solution and it works perfectly, thank you very much !
Imported from GitHub comment by @Jipforester on 2025-02-20T18:38:34Z
