Can I change how many file versions of an organization owned project are saved?
My organization project is quiet small (~100MB) but since there are 10 different file version I am already hitting the storage limit on my organization.
Is there anyway to reduce the file versions permanently? We intented to upgrade to a higher storage plan in the future, when more project are added to the organization, so manually deleting the backup versions would be too much of a hassle.
Imported from GitHub discussion by @Notramus on 2023-04-25T17:51:34Z
AFAIK this is not available as an option. You have to manage versions carefully as they will use up your quota.
Imported from GitHub comment by @wanderingnature on 2023-04-26T00:56:31Z
Being able to manage the number of versions would be indeed quite useful… The 10 versions are sometimes not enough if there are a lot of different users contributing to the project. Thus it would be for example really interesting to have a configurable number of versions per user in a project.
Imported from GitHub comment by @jguelat on 2023-04-26T14:57:32Z
Thanks for your feedback
Imported from GitHub comment by @Notramus on 2023-04-26T15:03:11Z
