Cannot update to QField 2.0 on Motorola G7
Hi there,
I used Qfield some time ago with Sync.
Now I use QFieldCloud. The project is on the cloud, but I can’t use the App, because it’s 1.10. Update fails, deinstall and install new brings only 1.10 not 2.0.
I use Motorola G4 with Android 7.0
Thanks for help!
Imported from GitHub discussion by @GDM-Tuebingen on 2022-04-19T13:48:52Z
Hey, GDM-Tuebingen, thanks for reaching out.
As we stated here QField 2.0 Arctic Fox is here – OPENGIS.ch
Please note that on older AMRv7 architectures, some devices are suffering from a crash at launch. As such, we have not yet updated QField to 2.0 for these devices. If you own one such device and want to manually download and install QField, please visit the release page on GitHub.
Imported from GitHub comment by @suricactus on 2022-04-19T20:21:23Z
Hi suricactus,
thank you for the replay.
Seems that I need a new smartphone. With apk Installation 2.0 crashes immidiatly after starting. Before I can open a project.
Imported from GitHub comment by @GDM-Tuebingen on 2022-04-21T08:07:10Z
GDM-Tuebingen , can you try the APKs here: Fix QField crashing on arm(v7) devices by nirvn · Pull Request #2773 · opengisch/QField · GitHub – the crashes on launch should hopefully be gone.
Imported from GitHub comment by @nirvn on 2022-04-21T11:11:08Z
GDM-Tuebingen , assuming your device is an armv7, use the arm-android APK.
Imported from GitHub comment by @nirvn on 2022-04-21T11:12:02Z
