Hi there everyone,
hope someone here can help, thanks in advance:
I would really love to enhance the experience for some of my collegues for using Qfield for collecting data in the field. Therefore I would like to integrate pictures, depending on the content of a form in QGIS, so that they than can edit the form while at work in qfield.
The main point is that, while collecting data, the user would benefit from the visualisation of his data and might clearly see if there is something wrong. Another benefit is, that in the end of a project I might be able to generate a QGIS-ATLAS that shows all the little pre-designed sketches of each object that was visited in the field together with some of the data, so that it appears to look at the data in categories rather than real life photos.
However I’ve attached a little sketch to show what I mean by this:
- I only want to show the content inside the blue box
- all of the symbols/ pictures would be pre-saved on the device of the qfield-user
- the appearence of the symbols for each data-point should be interchangable, depending on what the user fills out or chooses while collecting the data (sort of “live interchanging of the symbols” while using the form)
Do y’all think this is possible to integrate into a qgis form to use in qfield?
Any advise how to get started?
Thanks again & greetings!!!
Imported from GitHub discussion by @Adr1an113 on 2024-12-16T15:35:50Z
