How to delete my project on the cloud?
I have created several test projects that I do not use. How can I delete a project on the cloud that I don’t need?
Imported from GitHub discussion by @SerhiyKSV on 2021-11-26T12:28:16Z
Hi SerhiyKSV . Thanks for trying out QFieldCloud.
You can delete your project from the Web UI if you follow:
  1. you click on your project to be deleted
  2. go to “Settings” menu on the left
  3. in the bottom you will see in red “Delete this project” section
  4. make sure you are on the right project, this action is irreversible!
  5. click on the red button “Delete project”. You will see a new dialog.
  6. make sure again this is the correct project. If yes, then type the required text and press “Delete project”.
  7. Done! Hope it was the correct project.
Imported from GitHub comment by @suricactus on 2021-12-10T20:15:07Z
Imported from GitHub comment by @marioba on 2022-02-01T13:27:40Z
