How to replace the line or polygon of a feature
When I use QField in the field, I sometimes want to replace the line or polygon that is associated with a feature. For example, I have a layer for small ponds, and each feature has a polygon that is the shape of the pond. Sometimes the polygon is just wrong, and I want to walk the boundary of the pond and digitize points and replace the entire polygon of that feature.
I can’t figure out how to do that. I can delete the feature and create a new one, but then I have to re-enter all the attributes for that pond. The name and other attributes are all OK, I just want to update the polygon. I can edit the vertices of the existing polygon, but they are all wrong, I want to replace the entire shape, and do that by walking around and digitizing points, not by drawing a shape on the screen.
Is there any way to do that in QField? Thanks.
QGIS 3.30.1
QFIeld 2.8.1
Imported from GitHub discussion by @dm413 on 2023-06-10T23:28:07Z
