How to select multiple features on the map?
Is there a way to select multiple, geogrpahically not clustered, features?
I want to change certain attributes of multiple features which are not close to each other. Is there a way to select them one by one on the map, then access the attribute form and change the attribute? So far only the last part is working - when i select multiple features beacuse they are close to each other, i can change an attribute for all of them.
Imported from GitHub discussion by @meyerlor on 2025-03-19T08:35:03Z
Ah uh god, i feel stupid, right after posting i found it - i’ll keep the post though, maybe others profit from it. It is super easy:
  1. Select one feature on the map
  2. Three Dots (right corner) → Switch to feature selection
  3. TICK THE BOX of your desired feature (this step i was missing..)
  4. Now tap on the features on the map you want to add to your selection
  5. Change attributes for all of them by clicking on the “Edit Feature” Symbol
Enjoy :slight_smile:
Imported from GitHub comment by @meyerlor on 2025-03-19T08:38:46Z
You can also long press the layer name, click “Show feature list”, and then you can pick from all features with a long list.
Imported from GitHub comment by @suricactus on 2025-03-19T08:58:41Z
Wow, great! Thanks for the hint - great stuff! :slight_smile:
Imported from GitHub comment by @meyerlor on 2025-03-22T20:24:40Z
