Image File Size
we are capturing one to one images in our project. Overtime now the sync load is increasing due to the number of images. I was wondering if adding a zip archive as photo directory would work, especially while using the Cloud. Other tips on how you manage your photos would be great.
Thanks for the input.
Cu around
Imported from GitHub discussion by @Churros396 on 2024-07-01T14:40:20Z
JPGs are already compressed so not sure how much you gain by zipping them. In our system we have reduced the image size to suit the end use which which is much smaller than the default full resolution so saves loads of space.
Imported from GitHub comment by @BTreeTech on 2024-07-03T08:30:03Z
