Invalid datasource when trying to get postgis layer in qfield cloud
I am having this error. Please provide me a solution
INFO:root:QGIS project layer checks
Layer Name Layer Id Is Valid Status Error Summary Provider Summary
KEast_roads …aea30c True no_error
P73_boundary …4ea8df True no_error
P73_buildings …4cefe8 False invalid_dataprovider
Ward_KEast …bb5259 True no_error
Generate Thumbnail Image
INFO:root:Generate project thumbnail image…
WARNING:QGIS_MSGLOG:Connection to database failed
fe_sendauth: no password supplied
WARNING:QGIS_MSGLOG:1 unavailable layer(s) found:
WARNING:QGIS_MSGLOG: * dbname=‘prabhag122’ host= port=5432 sslmode=disable key=‘uuid’ type=MultiPoint checkPrimaryKeyUnicity=‘1’ table=“public”.“P73_buildings” (geom)
INFO:QGIS_STDERR:Stopping QGIS app…
Imported from GitHub discussion by @MonikaShah on 2022-07-26T07:44:09Z
It seems QFieldCloud can not connect to your database.
Here you have an explanation how to do it Postgis
  1. Is your database visible from internet
  2. Did you set up the secrets
Imported from GitHub comment by @lucienicolier on 2022-07-26T09:27:12Z
I tried adding the configs to secrets. But still I coudnt access it from
qfield on my mobile.
error that it has is
WARNING:QGIS_MSGLOG: * dbname=‘prabhag122’ host=162.55.169.58 port=5432
INFO:QGIS_STDERR:Stopping QGIS app.
On Tue, Jul 26, 2022 at 2:57 PM Lucie Nicolier @.***>
wrote:
https://docs.qfield.org/get-started/tutorials/advanced-setup-qfc/#postgis
    https://docs.qfield.org/reference/qfieldcloud/secrets/
https://github.com/opengisch/QField/discussions/3115#discussioncomment-3229481,
or unsubscribe
https://github.com/notifications/unsubscribe-auth/AA76P5PEP4A54NOTPMFBIY3VV6VPVANCNFSM54U4SYUQ
You are receiving this because you authored the thread.Message ID:
With Regards,
Monika Shah
Imported from GitHub comment by @MonikaShah on 2022-07-27T06:33:29Z
MonikaShah seems you have configured you PostGIS layer improperly. Are you sure you configured your layer to require a service with specific name?
Imported from GitHub comment by @suricactus on 2022-08-12T01:50:45Z
