Is there a attribute form close event i can use to populate a field?
I built a python init attribute form solution to capture the moment the form gets closed and write that datetime value to a field. However, then i learned python is not supported in Qfield. So is there another way to capture the datetime when a form is closed and write it to a attribute field?
I can set the field to a default value of to_string(format_date(now(),‘yyyy-MM-dd HH:mm:ss+t’)) AND set it to “apply default values on update” but that only works when i change something on the form. If i am mapping the same type of object repeatedly then i use the ‘remember last value’ function, i get to the object, open a new form and hit enter and i am done. In such a fast mapping case, since i change nothing on my form, the “form start” and “form end” fields will have the same timestamp in this case.
  1. it would be great if there was python support in QFIeld but i imagine that is easier suggested than done.
  2. instead of only offering “apply default values on update” …it would be great to include other event patterns “set once on load”, “apply on close/enter”, ( but that would be a QGIS enhancement i guess. )
Imported from GitHub discussion by @r3tlove on 2023-07-08T21:13:47Z
I’ve been looking for events for QField as well. Posted a feature idea (link below) you may like to take a look at/vote on.
Cheers
In QGIS, go to Layer_Propoerties_Attribures Form. Highlight your field in Available widgets or Form layout and then in the right hand pane for widget configuration, scroll to bottom and set polcy for when duplicating feature to ‘Use Default Value’.
