Only identify feature in current layer?
Whenever I click on a feature in the QField app it will always show features from all layers. This can be confusing to users, because they have to search for the correct layer to select the feature they want to identify or edit.
This behaviour is the same in browser mode and in Digitize mode.
A project can have multiple layers that are used for different purposes, but are not necessarily the main layer for editing. The Sync settings only allow “offline editing” or “remove from project” for geopackage layers.
Is there a way to only show the layer that is actually used for editing?
Or set something like the Identify mode in QGIS:
afbeelding
This Identify mode is not a project setting in QGIS, and as such it doesn’t automatically transfer over to QField.
Found it, it is a QGIS setting in Project Properties > Data Sources. Here you can set the status Identifiable for each layer. When unchecked, the layer will not be shown in the Identify screen.
