Prepare QField Project for offline editing
Hi.
I have a project containing numerous layers. They are a mix of shp files and geopackage layers.
All the shp files are information only - so locked geometries when configuring QField.
There are two spatial layers to edit - a point later and a polygon layer, and these each have three non-spatial relations, which will also be edited. These are all geopackage layers.
I can successfully create the project by cable export with cable layer action for all layers set to copy.
But, trying to create a QFieldCloud Project for offline editing fails. I get the following log messages
2022-10-14T15:53:55 WARNING The layer ‘Lou_OSM_Areas’ could not be converted and was therefore removed from the cloud project.
2022-10-14T15:53:55 CRITICAL The project could not be converted into the export directory.
The layer ‘Lou_OSM_Areas’ is a SHP file. It is encoded UTF-8. Locked geometries. It is an OS Mastermap extract. I have other similar OS Mastermap extracts for which there are no errors reported.
I have also tried creating an offline project using cable export. This does not produce any errors, but the two spatial layers and one of the relations from thre geopackage cannot be loaded.
Any pointers to help me resolve this?
Thanks in advance
Imported from GitHub discussion by @Oisin-JK on 2022-10-14T15:13:10Z
