I don’t make to visualize photo to an object just took. QField takes photos and add the path and the name of the file but it seems QField doesn’t save the file. QField displays an icon which announce it can’t found the file. But the file is saved in the DCMI folder filed the project folder.
When i created the project file in Qgis, i added in my attributes table, the “Photo” field. Finally, in Layer Properties-> Attributes Form, I set up the widget type to Attachment.
Imported from GitHub discussion by @stefanoch90 on 2022-08-31T10:04:58Z
Unless I am missing something, I am also having this issue as described above. I create a project in QGIS, synch it to QField via QFieldCloud. Out in the field I add a feature and take a photo. I synch this back to QFieldCloud and the QGIS project. I can see the point I have recorded and the image file name but I cannot find the image saved anywhere in the cloud or within my QGIS project.
Maybe I am missing something - any ideas?
Imported from GitHub comment by @ConnicksGIS on 2023-01-11T11:09:16Z
stefanoch90 ConnicksGIS can you please let us know what QField and device you are using?
Imported from GitHub comment by @suricactus on 2023-01-11T11:33:07Z
Hi Ivan, I had the same problem as you the first time I used QField. I solved it in the following way:1) I created a new project file in QGIS and saved the data inside a folder.2) I connected my smartphone to my notebook and dragged the QGIS project folder inside the QField folder in my smartphone.In this way I solved the problem of not displaying the image taken in the field.I hope this solution helps you as well.See you soon Ing. Stefano ChiappiniBuilding Engineer; PhD ResearcherUniversità Politecnica delle Marche - Dept. of Agricultural, Food and Environmental Sciences – D3AVia Brecce Bianche 10, 60131, Ancona, Italy
Imported from GitHub comment by @stefanoch90 on 2023-01-11T11:37:52Z
