It is a bit rough, but a proof of concept for the new sensor feature in QField.
Setup:
- Fairphone 3 (LineageOS 20.0 / Android 13)
- Termux-app (GitHub - termux/termux-app: Termux - a terminal emulator application for Android OS extendible by variety of packages.)
- Termux:api (GitHub - termux/termux-api: Termux add-on app which exposes device functionality as API to command line programs.)
- Node-Red installed via termux (Running on Android : Node-RED)
- access termux-sensor (Phones internal Magnetometer, Making sure you're not a bot!) via exec node in node red, parse json values (x/y), calculate direction, push direction values out on udp-port
- Qgis master (to setup qgis project with sensors configured and default values)
Screen cast:
Remarks:
Calculation of direction is set up to look ‘nice’ in QField/QGIS. I had to tweak the values (from -180°…180° to 90°…450°). I think thats ok for a proof of concept, but not for production use.
Node-red Flow:
[ { "id": "491a6cbdbe77f041", "type": "tab", "label": "Flow 2", "disabled": false, "info": "", "env": [] }, { "id": "9b064615129a5962", "type": "json", "z": "491a6cbdbe77f041", "name": "", "property": "payload", "action": "", "pretty": false, "x": 970, "y": 420, "wires": [ [ "5af39c2b07607afe", "890e1732aac8ca43", "ec60eb94962beb7f", "eb3baec5b79e3ca1", "692f7216f2c5dfe3" ] ] }, { "id": "5af39c2b07607afe", "type": "function", "z": "491a6cbdbe77f041", "name": "Get the number X", "func": "msg.payload = Math.round(msg.payload[\"AK09918 Magnetometer\"][\"values\"][0]*1000)/1000;\nreturn msg", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 1170, "y": 320, "wires": [ [ "ca476548b30219a4" ] ] }, { "id": "ca476548b30219a4", "type": "debug", "z": "491a6cbdbe77f041", "name": "x", "active": false, "tosidebar": true, "console": true, "tostatus": false, "complete": "payload", "targetType": "msg", "statusVal": "", "statusType": "auto", "x": 1390, "y": 320, "wires": [] }, { "id": "890e1732aac8ca43", "type": "debug", "z": "491a6cbdbe77f041", "name": "debug 12", "active": false, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 940, "y": 340, "wires": [] }, { "id": "6a945747f4cf57e8", "type": "debug", "z": "491a6cbdbe77f041", "name": "debug 13", "active": false, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 940, "y": 600, "wires": [] }, { "id": "ec60eb94962beb7f", "type": "function", "z": "491a6cbdbe77f041", "name": "Get the number Y", "func": "msg.payload = Math.round(msg.payload[\"AK09918 Magnetometer\"][\"values\"][1]*1000)/1000;\nreturn msg", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 1170, "y": 380, "wires": [ [ "1e41f0f904c929f2" ] ] }, { "id": "eb3baec5b79e3ca1", "type": "function", "z": "491a6cbdbe77f041", "name": "Get the number Z", "func": "msg.payload = msg.payload[\"AK09918 Magnetometer\"][\"values\"][2];\nreturn msg", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 1170, "y": 260, "wires": [ [ "479142d984452a38" ] ] }, { "id": "82c6b3dcb13cc70d", "type": "udp out", "z": "491a6cbdbe77f041", "name": "", "addr": "127.0.0.1", "iface": "", "port": "50001", "ipv": "udp4", "outport": "", "base64": false, "multicast": "false", "x": 1740, "y": 440, "wires": [] }, { "id": "1e41f0f904c929f2", "type": "debug", "z": "491a6cbdbe77f041", "name": "y", "active": false, "tosidebar": true, "console": false, "tostatus": false, "complete": "payload", "targetType": "msg", "statusVal": "", "statusType": "auto", "x": 1390, "y": 380, "wires": [] }, { "id": "479142d984452a38", "type": "debug", "z": "491a6cbdbe77f041", "name": "debug 14", "active": false, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 1400, "y": 260, "wires": [] }, { "id": "692f7216f2c5dfe3", "type": "function", "z": "491a6cbdbe77f041", "name": "direction degrees", "func": "msg.payload = Math.round(\n (\n (\n (Math.atan2((msg.payload[\"AK09918 Magnetometer\"][\"values\"][1]),\n (msg.payload[\"AK09918 Magnetometer\"][\"values\"][0])\n )\n )*180\n ) / Math.PI +270\n )*10\n )/10 ;\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 1170, "y": 460, "wires": [ [ "168090b23fd3f5f5", "82c6b3dcb13cc70d" ] ] }, { "id": "168090b23fd3f5f5", "type": "debug", "z": "491a6cbdbe77f041", "name": "deg", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "payload", "targetType": "msg", "statusVal": "", "statusType": "auto", "x": 1690, "y": 500, "wires": [] }, { "id": "be67f6f65eb73158", "type": "function", "z": "491a6cbdbe77f041", "name": "name sensor 1", "func": "msg.payload = \"Magnetometer Calc Degree\"\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 1160, "y": 520, "wires": [ [ "528f403a101caa45", "33cd2facc047c7de" ] ] }, { "id": "528f403a101caa45", "type": "debug", "z": "491a6cbdbe77f041", "name": "debug 15", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 1700, "y": 620, "wires": [] }, { "id": "33cd2facc047c7de", "type": "udp out", "z": "491a6cbdbe77f041", "name": "", "addr": "127.0.0.1", "iface": "", "port": "50011", "ipv": "udp4", "outport": "", "base64": false, "multicast": "false", "x": 1740, "y": 560, "wires": [] }, { "id": "fb47fed99b6b2711", "type": "exec", "z": "491a6cbdbe77f041", "command": "termux-sensor -s \"AK09918 Magnetometer\" -n 1", "addpay": "payload", "append": "", "useSpawn": "false", "timer": "", "winHide": true, "oldrc": false, "name": "", "x": 660, "y": 420, "wires": [ [ "9b064615129a5962", "6a945747f4cf57e8" ], [], [] ] }, { "id": "187b66167d4f67e0", "type": "inject", "z": "491a6cbdbe77f041", "name": "", "props": [ { "p": "payload" } ], "repeat": "3", "crontab": "", "once": true, "onceDelay": "", "topic": "", "payload": "", "payloadType": "date", "x": 550, "y": 260, "wires": [ [ "fb47fed99b6b2711", "be67f6f65eb73158" ] ] } ]
Imported from GitHub discussion by @soester on 2023-04-19T08:27:29Z
