QFieldCloud planned maintanance on 10th August
For a few hours QFieldCloud will not be available as a service.
Imported from GitHub discussion by @suricactus on 2022-08-09T22:18:16Z
Hi Suricatus,
Is this why I do not see the majority of my projects on the website?
I see something new in the projects remaining:
Imported from GitHub comment by @gabgarcies on 2022-08-10T07:47:01Z
I have this same problem. 70% of my project dissapear from cloud. Can you check this? Or maybe now theres a limit of project number?
Imported from GitHub comment by @Alekssssanderr on 2022-08-10T07:50:08Z
I have the same problem as Alekssssanderr , but additionally nearly all my collaborators were kicked out of the still remaining projects.
Imported from GitHub comment by @Notramus on 2022-08-10T10:18:01Z
I have a problem. My entire project was deleted from the cloud. What should I do? Should I wait after the maintenance?
Imported from GitHub comment by @DumitruD87 on 2022-08-10T10:18:04Z
gabgarcies Alekssssanderr Notramus DumitruD87 we are looking into your issues.
Your projects are most probably not deleted, but unaccessible, since we enforced some new account permission rules that are close to what is going to be when QFieldCloud goes out of BETA. Please contact the project owner of the “missing” projects, they should see them and fix the issue.
Something you should be aware of is that you are allowed of maximum of 1 coollaborator per private project. Please transfer your projects to an organization to collaborate with more users.
Imported from GitHub comment by @suricactus on 2022-08-10T10:49:27Z
I am the project owner of the “missing” projects. But i can’t see all my project. One is missing.
Imported from GitHub comment by @DumitruD87 on 2022-08-10T10:57:44Z
thanks for the screenshot, I will keep you posted. Your project is intact and it is not showing because you have more collaborators than allowed. Obviously not showing the project is not ok and we are working on it.
Imported from GitHub comment by @suricactus on 2022-08-10T11:12:18Z
OK. Good. Can all collaborators be deleted? To stay only me?
Imported from GitHub comment by @DumitruD87 on 2022-08-10T11:20:23Z
Thank you very much!
Imported from GitHub comment by @DumitruD87 on 2022-08-10T11:21:47Z
suricactus I’m the project owner and I can’t see missing project in cloud. What should I do?
Imported from GitHub comment by @Alekssssanderr on 2022-08-10T11:32:23Z
suricatus I am as well the project owner. Thanks for your help. I will be waiting until the project appears.
Imported from GitHub comment by @Notramus on 2022-08-10T11:49:12Z
OK, I might understand why the projects have disappeared.
The missing projects are private projects (out of any organization) and they have more than 2 collaborators.
In my case, I am the owner of all the missing projects (more than 10) and they usually have 5 collaborators.
I have no problem at putting them into an organization and starting a billing plan. Actually, we do have an organization created in QfieldCloud (FUEIB_Eivissa), but the projects had not been created in it.
Now, I am not able to insert the missing projects into the organization (as I am not seeing them anymore on the website).
My question is:
Would that be possible for you to make this change for me: putting my private projects (user gabgarcies) into the organization I mentioned before (FUEIB_Eivissa)?
If not, what alternatives do I have? The biggest problem now is that my fieldworkers continue collecting data, as they had already downloaded the projects on their devices. We do not know what will happen once they push changes.
Thank you so much,
Gabriel Garcies
Imported from GitHub comment by @gabgarcies on 2022-08-10T12:59:05Z
Hey, gabgarcies you are following the conditions correctly. The interface willl suggest you to transfer them to an organization. This is already implemented. The issue is that the projects are hidden you cannot see this page. It’s something we identified and working on it.
Your field collectors should be able to push the project once it has the projects have valid number of users according to your plan (e.g. organizations are limitless).
Imported from GitHub comment by @suricactus on 2022-08-10T13:06:51Z
OK, I will do the transfer to an organization as soon as I recover the projects unseen.
In the meanwhile, can my fieldworkers continue working locally or what do you recommend me?
Imported from GitHub comment by @gabgarcies on 2022-08-10T13:16:21Z
Everything works fine and I have been able to move the projects to an organization.
Thank you!
Imported from GitHub comment by @gabgarcies on 2022-08-11T07:26:20Z
gabgarcies Alekssssanderr Notramus DumitruD87 juwizeye TheJoseph24 I hope now you can enjoy the new features of QFieldCloud without an issue.
Imported from GitHub comment by @suricactus on 2022-08-11T09:11:20Z
