QGis Desktop configure QfieldCloud with a standalone instance
I’am trying to configure a QGIS project to use a local standalone QFieldCloud instance.
My instance is accessible with https://localhost
The problem comes that i have already configure QGIS Desktop to use https://app.qfield.cloud/ as a server.
How I could create several connection to different QFieldCloud server ?
Or - at least - how could reconfigure se actual connection ?
Hello, all you need to do is double-click the Ninja icon in the QFieldCloud login dialog. Another input field will appear where you can change the server URL.
Yes Thank you, I finally got it (double click on a icon is not fully intuitive :wink: - and -my bad it’s already explain in documentation…).
Now I faced a new problem :
  • My QFieldCloud is started with a selfsigned certificate
  • How configuring my QField desktop to accept it ? (actually i got a ssl handshake)
I try to had the generated certificate found in config/nginx/certs to C:\Program Files\QField\usr\share\cacert.pem but it does not work.
