Sync issues with off-line editing
Hi - Sync problem: for example, we have a field called baseline habitat type, and then a field called sub-type etc. After editing these off-line on QField, when I sync back to the Qgis project, it says “successful”, no errors, but nothing appears to be uploaded. The attribute table for the edited layer remains empty. I can open the QField project in QGis, the edited fields are present in the layer, but in a slightly different form - the baseline habitat type is now in a different column, and the sub-type is in brackets etc. The georeferencing is correct, so I can copy and paste into the QField layer, the polygons will appear on the map without symbology, and then I can edit the field entries around so that they are correct again, but I have NO idea how to resolve this, and it seems to be a new bug…would greatly appreciate help - p.s. as you may be able to tell, I am no GIS expert!
Hi Gman,
Do you have a sample project.?
Can you see the changes in QFieldCloud ?
What version of QGIS and QField did you use for the preparation and while being in the field ?
Best
Berit
