A QField plugin template with CICD integrations, QR codes and fancy tooling
Hi there, QField plugin creators and maintainers,
Want to share with you a recently initiated project:
A template that generates a QField plugin, ready-to-go and boiler-plated with CICD integrations and workflows, QR code generation, translations framework, automatic releases, fancy tooling around.
→ https://qfield-plugin-templater.gounux.net
Currently integrable with GitHub and GitLab, the generation consists in running one command, then the prompts guide you. Basically:
pipx run cookiecutter gh:gounux/qfield-plugin-templater
The code repository is here: https://github.com/gounux/qfield-plugin-templater
Since this project is more focused on the tooling around the plugin, the generated QML and the “GIS features” brought by this QField plugin template are quite basic,
Though, I’d like to also express that this project is in its early stages, and welcomes feedback & contributions !
Thus if you see nice things to add to the plugin, toolings around a QField plugin template generation, please :slight_smile:
