I am using QGIS + QField with a GeoPackage.
I have a parent-child relation:
Parent layer: Parcela
Field: uuid_parcela
Child table: Arboles
Fields:
uuid (foreign key to parcela)
ID_Arbol (integer)
Trees are created from the relation widget inside the parcela form.
What I want is this:
When creating a new tree in the form, ID_Arbol should automatically be the maximum value of ID_Arbol for that same uuid plus 1.
This increment must be per parcela, not globally.
Example:
For parcela with uuid = A, if the existing tree IDs are:
1
2
3
the next tree should automatically be:
4
But if I create trees in another parcela with uuid = B, numbering should start again from:
1
Another important point:
sometimes the suggested value may be changed manually before saving.
If that happens, the next new tree should still consider the maximum saved value for that parcela.
Example:
for parcela A, if the saved values are:
1
2
3
3
then the next new tree should be:
4
Important requirement:
the number must appear in the form before saving, because the field crew needs to see the tree number immediately.
I tried using aggregate(), relation_aggregate(), and SQLite triggers.
Triggers work correctly after saving, but the value does not appear in the form before saving.
My question is:
Is there a recommended way in QField forms to calculate the next ID_Arbol as MAX(ID_Arbol) + 1 for the current parcela (same uuid), so that numbering restarts at 1 for each parcela and still works correctly even if some values are manually edited?
Thanks!
