We have installed QFieldCloud v0.26.5 on our own server. The synchronization of projects with geopackages works well. However, we would like to create a project that uses layers from a PostGIS database to update the layers directly in the database.
We noticed that QFieldCloud uses secrets for connecting to a PostGIS database. However, we don’t see an option to configure these secrets in the admin interface.
We read in this discussion (Secrets on self-hosted QFieldCloud · opengisch/QField · Discussion #4771 · GitHub) that the secrets are not yet accessible from the interface. To connect QFieldCloud to PostGIS, should we revert to an older version? If so, which version would you recommend and is it available? When do you think this feature will be available in the interface? Can the QFieldCloud SDK help to work around this issue?
Thank you for your assistance.
Imported from GitHub discussion by @sigsdis30 on 2024-06-03T13:24:31Z
