Delta apply job failed on uploading project
I am having trouble locating the problem in our latest changes which leads to the failed “Delta apply job”.
If I manually reapply the changes via the “changes” tab in QFIELD Cloud it changes to pending and later to error again.
Looking at the jobs it seems that the uploading part is failing:
09:18:57.313 root INFO Local files list for project “a10e242d-4083-4b92-a850-0e47d9939b94”:
Name Size MD5 Checksum
DeleteLater.qmd 1056 bbfe08e8abf4aedf75e377c692d78a5e
DeleteLater.sqlite 6684672 f047f06ef05717e403e74f10ffcf10df
Freiburg_2022.qgs 1616832 072a31dfc36e84235f9795875b1afa8c
Hintergrund/Hintergrund.qmd 672 da362a0f0e67483b58de35320614f36c
Hintergrund/Hintergrund.sqlite 79015936 db43dccd0e5af4d0f807748d352affb4
Kontrolle noch notwendig.dbf 229 777a48d24938b2b6e2ff3825f8f4f7d3
Kontrolle noch notwendig.prj 145 c742bee3d4edfc2948a2ad08de1790a5
Kontrolle noch notwendig.shp 112 876cde9302b982ff13f7fe5ad5d8283c
Kontrolle noch notwendig.shx 108 3b6c7ad7fbcf586281feeb71b3c3449c
Kontrolle/Kontrolle.qmd 1057 ef0fea7fb26306c6cf93c3593b9a8600
Kontrolle/Kontrolle.sqlite 51527680 578356a12131d07010565a20d0faa1a3
Monitoring/01_03.csv 13805 3693092907163aa10abec35354a817cc
Monitoring/Monitoring_2022.sqlite 6893568 68c2e355dbcce39e95666458fe2b0d5d
Monitoring/csv/Kontrolle 1_2_3_4_5.csv 21482 7160a69001c01531d9977aafeb832c3a
Personal/Sonstiges.sqlite 6742016 1c29e53ee28665a72989af363ce29440
Vermutete Ausbreitung.dbf 110 34d072cd807024408821d54264bd6b4b
Vermutete Ausbreitung.prj 145 c742bee3d4edfc2948a2ad08de1790a5
Vermutete Ausbreitung.shp 728 d9310da33c4406598b9d24c026d5e692
Vermutete Ausbreitung.shx 132 f9a0ff226df159315e8a856204f69070
delete.qmd 672 da362a0f0e67483b58de35320614f36c
delete.sqlite 63950848 b06c55ee355feba1851aeee5860e2908
Does anyone have any idea?
Imported from GitHub discussion by @Notramus on 2022-09-14T09:50:03Z
Thanks for pointing this out. The reason was that jobs had a very low limit of 60 seconds before getting timed out. Now the timeout is set to 10 minutes and all should be good if you rerun the job apply.
Imported from GitHub comment by @suricactus on 2022-09-14T10:32:01Z
Thanks for the help! I have tried reapplying the changes, but it still failed after a few minutes?
Imported from GitHub comment by @Notramus on 2022-09-14T10:52:59Z
Can you try again now?
Imported from GitHub comment by @suricactus on 2022-09-14T11:15:46Z
Everything working as intented now! Thanks a lot Suricactus :slight_smile:
Imported from GitHub comment by @Notramus on 2022-09-15T18:09:41Z
