While the Qcloud is down is there a way to export collected data manually via a cable? I have 3 days of data to export and i’m worried it is going to be lost.
Imported from GitHub discussion by @mrgrimshaw on 2023-01-26T16:35:24Z
Open the project you want to fetch go to setting → open project folder and then you can export each item .
good luck
Imported from GitHub comment by @Duckrichard on 2023-01-27T07:23:26Z
This works great on android but it not an option on ios. Any ideas?
Imported from GitHub comment by @mrgrimshaw on 2023-01-27T10:59:48Z
hey mrgrimshaw since yesterday evening QFieldCloud is up and running again. A fix has been deployed; all systems are operational again and we’are monitoring the situation.
Indeed in iOS there is no export functionality yet. It’s something we’re assessing currently.
Imported from GitHub comment by @mbernasocchi on 2023-01-28T09:27:40Z
mbernasocchi Any progress in this: exporting local project from iOS? This is a very nice “backup”-solution on Android if, for some reason, mismatch between local project and cloud project. See also https://github.com/opengisch/QField/discussions/4358 and https://github.com/opengisch/QField/discussions/4371 if there is way of getting the local data from an iPhone or iPad.
Imported from GitHub comment by @9ls1 on 2023-10-05T13:34:44Z
