GPS positioning problem in Lambert 93
Hrllo,
I am testing GPS location on QField windows with a simulator: Virtual GPS.
If my Qfield project is in EPSG 4326, no problem.
If it is in EPSG 2154 (Lambert 93), the GPS position and the shp layers (also in 2154) are very off.
Do I always have to work in EPSG 4326?
THANKS
Cordially
Gerard
Imported from GitHub discussion by @geguill on 2023-05-04T13:34:14Z
geguill , can you define very off?
Imported from GitHub comment by @nirvn on 2023-05-04T14:06:38Z
Sorry.
GPS position is in the wrong place relative to the layers.
Imported from GitHub comment by @geguill on 2023-05-04T14:22:58Z
Heh, that was clear already :wink: are we talking about 1 meter off or “the other side of the globe” off?
Imported from GitHub comment by @nirvn on 2023-05-04T14:27:27Z
About 5000 km to the south
Imported from GitHub comment by @geguill on 2023-05-04T14:29:41Z
geguill , ok, if you can attach a test project with a video that’d be of help
I’d try to check whether an epsg 4236 point layer reprojects properly in your epsg 2154 project within QGIS first. If there’s a problem there, it’s likely a project setting issue.
Imported from GitHub comment by @nirvn on 2023-05-04T14:35:10Z
essai_5.zip
Imported from GitHub comment by @geguill on 2023-05-04T15:07:39Z
I have the exact same probleme.
QFIELD Lons.zip
Imported from GitHub comment by @Exebecce on 2023-07-19T12:56:48Z
Do you have news about this problem ? It makes a while I didn’t use Qfield and I’ve got the same problem with the 2.8.7 version and Lambert 93 project. My vectorial data are in lambert 93, the basemap is also generated in Lambert 93, but when activating the GPS, this one is in WGS84 !
So I can’t see the data while activating the GPS off course.
In oldest version, I didn’t have such a problem.
test_stavertin_230905.zip
Imported from GitHub comment by @ludodo on 2023-09-05T12:56:26Z
To complete, I downgrade Qfield to version 2.7.6 and it works great, so something has been broken.
Imported from GitHub comment by @ludodo on 2023-09-05T13:35:59Z
ludodo , could you try to provide us with NMEA logs of your device from QField?
Documentation on how to do that is found here: Positioning (GNSS) - QField Ecosystem Documentation
Imported from GitHub comment by @nirvn on 2023-09-05T14:31:48Z
For me, the problem has been solved by deleting Qfield from the smartphone and installing it back.
Reply to this email directly or view it on GitHub:
GPS positioning problem in Lambert 93 · opengisch/QField · Discussion #4258 · GitHub
You are receiving this because you commented.
Message ID: @.***>
Fabien Leprince
Imported from GitHub comment by @Exebecce on 2023-09-05T18:14:54Z
Not for us, and on twos different devices
Imported from GitHub comment by @ludodo on 2023-09-08T12:17:00Z
I do not use an external receiver. so I don’t have the option proposed in the positionning window.
On one off the device, installing a version 2.7.6 works, and then, update to 2.8.7 doesn’t brake the resolution.
But on anther device (crosscall), it doesn(t work with any version.
Imported from GitHub comment by @ludodo on 2023-09-08T12:29:44Z
