Hi all!
I’m using QField (and QFieldCloud) to perform field measurements and would like to record x, y (in Belgian Lambert 72, EPSG 31370) and orthometric height (m above TAW) for my points. Getting x and y is no problem at all, but I don’t manage to get the orthometric height working. I put a grid shift file (.gsb) on the device and can select it in the Positioning tab of the QField Settings. But if I select this vertical grid shift file or not, the recorded z(@position_coordinate) value is the same. The “Skip altitude correction“ is disabled.
I’m wondering why this could be. Do we only apply the grid shift in certain configurations/certain receivers/…? What can I check and verify?
Thanks a lot for the help.
