Invalid dataprovider
Hi, RubenSadei.
Yes, QFieldCloud assumes all your files are in the same directory. There is an upcomming functionality for QFieldSync to collect all your files in the same folder, so you don’t need to do this manually.
On the Google Satellite problem, can you elaborate more? What do you mean by “partially loads the image”? What is the image - a local raster file, WMS, XYZ layer? Did you mark it also as base layer? BTW, feel free to open a new question in discussion to resolve your Google Satellite problem.
Imported from GitHub comment by @suricactus on 2021-06-22T12:59:36Z
