I have a project stored on acugis consisting of a point layer “boom”, a table without geometry “controle”, that have a 1:n relation and a view “distinct” joining the 2 tables. I want the convert it to an offline project on qfield cloud, using the plugin. The upload seems succesfull.
I also added a secret
But when I open the project in qfield I get the following error message and only the view is vissible in the project.
[14:06, 28-07-2022] Thomas Tablet: Project bb13f433-6b36-4aaa-803a-52c1f99a917a: Packaged layer vta
is not valid. Error code invalid_dataprovider, error message: File "/Documents/vta.gpkg" missing. [14:06, 28-07-2022] Thomas Tablet: Project bb13f433-6b36-4aaa-803a-52c1f99a917a: Packaged layerboomveiligheid
is not valid. Error code invalid_dataprovider, error message: File "/Documents/boomveiligheid.gpkg" missing. [14:06, 28-07-2022] Thomas Tablet: Failed to upload delta file, reason: Error transferring https://app.qfield.cloud/api/v1/deltas/1d1c09be-fafb-456f-96a9-7d61d8afe703/ - server replied: Bad Request [QF/object_not_found] Object not found [14:06, 28-07-2022] Thomas Tablet: Failed to upload delta file, reason: Error transferring https://app.qfield.cloud/api/v1/deltas/1d1c09be-fafb-456f-96a9-7d61d8afe703/ - server replied: Bad Request [QF/object_not_found] Object not found [14:07, 28-07-2022] Thomas Tablet: [QF/object_not_found] Object not found [HTTP/400] https://app.qfield.cloud/api/v1/deltas/1d1c09be-fafb-456f-96a9-7d61d8afe703/ Server fout.{"code":"object_not_found","message":"Object not found"} {"code":"object_not_found","message":"Object not found"} Error transferring https://app.qfield.cloud/api/v1/deltas/1d1c09be-fafb-456f-96a9-7d61d8afe703/ - server replied: Bad Request [14:07, 28-07-2022] Thomas Tablet: Project bb13f433-6b36-4aaa-803a-52c1f99a917a: Packaged layerboom
is not valid. Error code invalid_dataprovider, error message: File "/Documents/boom.gpkg" missing. Project bb13f433-6b36-4aaa-803a-52c1f99a917a: Packaged layerboom
If I look at the offline project in qgis the path of both the layer “boom” and the layer “control” the one goes to documents and the other to downloads.
A want to add that i have tested it with making the changes directly on the server and that worked fine.
Imported from GitHub discussion by @ThomasDV1984 on 2022-07-27T14:07:45Z
ThomasDV1984 Your QGIS is most probably configured to store absolute paths. Please check if this is the case.
Also, in case you want QFieldCloud to connect to your pg database directly, you should chose the second radio option in QFieldSync when creating and uploading the project.
Imported from GitHub comment by @suricactus on 2022-07-29T02:04:20Z
The path is set to relative.
Imported from GitHub comment by @ThomasDV1984 on 2022-07-29T13:46:21Z
And the layer “boom” I see in the qfieldcloud project created in qgis is not the same as the layer “boom” uploaded on the qfieldcloud server. The one on the server is the correct one but it cannot be opened on the app.
Imported from GitHub comment by @ThomasDV1984 on 2022-07-29T13:49:35Z
Can you upload a test project for more detailed answer instead of shooting in the dark. Thanks!
Imported from GitHub comment by @suricactus on 2022-07-29T18:12:12Z
boomcontrole.zip
This is the project that is stored locally. If you need acces to my database I have to make a login.
In addition in this project is a geopackage called “VTA” it is not part of the project and comes from an other db but is syncs in anyway.
Imported from GitHub comment by @ThomasDV1984 on 2022-08-01T06:23:45Z
Is this an issue or something for support?
Imported from GitHub comment by @ThomasDV1984 on 2022-08-17T09:23:50Z
To be very honest I didn’t manage to look at it yet, busy delivering the new QFieldCloud version. Sorry for the delay. I will try to have a look until the end of the month, in the mean time you can see if the new version magically solved your issue.
Imported from GitHub comment by @suricactus on 2022-08-17T14:28:54Z
Hm, it seems it’s not only the vta.gpkg that is missing?
Imported from GitHub comment by @suricactus on 2022-08-17T18:26:50Z
When you upload your project to the cloud, the error message you get is:
::<<<::cdc0f5cc-2192-45ba-b18d-2689d93b0a22 QGIS Layers Data
WARNING:QGIS_MSGLOG:Cannot open /Documents/boom.gpkg ().()
WARNING:QGIS_MSGLOG:Cannot open /Documents/boomveiligheid.gpkg ().()
WARNING:QGIS_MSGLOG:Cannot open /Documents/vta.gpkg ().()
WARNING:QGIS_MSGLOG:3 unavailable layer(s) found:
WARNING:QGIS_MSGLOG: * ../../../Documents/boom.gpkg
WARNING:QGIS_MSGLOG: * ../../../Documents/boomveiligheid.gpkg
WARNING:QGIS_MSGLOG: * ../../../Documents/vta.gpkg
INFO:root:QGIS project layer checks
Layer Name Layer Id Is Valid Status Error Summary Provider Summary
OpenStreetMap ...e20777 True no_error
boom ...17a990 False invalid_dataprovider File "/Documents/boom.gpkg" missing.
boomveiligheid ...fedfb1 False invalid_dataprovider File "/Documents/boomveiligheid.gpkg" missing.
distinct ...7f51cb True no_error
non_distinct ...6132a9 True no_error
vta ...e25fcb False invalid_dataprovider File "/Documents/vta.gpkg" missing.
Please make sure all your files are within the directory that holds the .qgs file. Also, please make sure all the layers are using these files, not those in Downloads or Documents directory.
In the meantime I will add this as a warning in QFieldSync.
Imported from GitHub comment by @suricactus on 2022-08-18T07:20:46Z
