Hello all,
at first thanks for your nice software.
Here comes my Problems - i think the most of them are because i am to new at the qfieldcloud world.
I installed a Debian server - after fresh install i followed your readme.me file.
The qfieldcloud is running, but I have some problems with it.
first the running situation:
I changed the .env file and the docker-compose.yml for my company.
And here starts my first question:
what is meant by your sentence
“Do not forget to set DEBUG=0 and to adapt COMPOSE_FILE to not load local development configurations”
Did you meen - i have changed thiese line in the .env file?
COMPOSE_FILE=docker-compose.yml:docker-compose.override.local.yml to
If i do these the server not run
so i let the value by default.
Now the server runs- but i have another problem:
i added an Subscription plan, an organization an some people - all works fine
i startet qgis with the qfield plugin and uploaded an project - no problems.
i can upload or download it … if i delete the project localy i can download it - alls works fine - ON my PC.
now i go to my ipad or an android tablet an will download the project but it ends with the error
Finised with an error: Packaging job finished unsuccessfully for 'projekt-titleXYZ.JOB(ID.....) finished with a failed status.
ok so i look ath the jobs on my admin panel - i show you here the error from “View-Jobs Site”
"error": "('Connection aborted.', PermissionError(13, 'Permission denied'))",
"error_origin": "worker_wrapper",
"error_stack": [
" File \"/usr/src/app/worker_wrapper/wrapper.py\", line 119, in run\n exit_code, output = self._run_docker(\n",
" File \"/usr/src/app/worker_wrapper/wrapper.py\", line 249, in _run_docker\n container: Container = client.containers.run( # type:ignore\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/models/containers.py\", line 802, in run\n container = self.create(image=image, command=command,\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/models/containers.py\", line 861, in create\n resp = self.client.api.create_container(**create_kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/api/container.py\", line 430, in create_container\n return self.create_container_from_config(config, name)\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/api/container.py\", line 440, in create_container_from_config\n res = self._post_json(u, data=config, params=params)\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/api/client.py\", line 289, in _post_json\n return self._post(url, data=json.dumps(data2), **kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/utils/decorators.py\", line 46, in inner\n return f(self, *args, **kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/docker/api/client.py\", line 226, in _post\n return self.post(url, **self._set_request_timeout(kwargs))\n",
" File \"/usr/local/lib/python3.10/site-packages/requests/sessions.py\", line 590, in post\n return self.request('POST', url, data=data, json=json, **kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/requests/sessions.py\", line 542, in request\n resp = self.send(prep, **send_kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/requests/sessions.py\", line 655, in send\n r = adapter.send(request, **kwargs)\n",
" File \"/usr/local/lib/python3.10/site-packages/requests/adapters.py\", line 498, in send\n raise ConnectionError(err, request=request)\n"
Hope someone can help me please
Imported from GitHub discussion by @freakofevil on 2023-05-17T15:15:08Z
