I’ve successfully uploaded a QGIS project to a self-hosted QC install. All has gone well and the project is showing on ‘QFieldCloud admin’ page and on an Android 13 device on the ‘My Projects’ tab. When I try to download the project it fails with the error (Downloading error.) with a ‘red’ dot prefixing the error. No other explanation.
The Message Log shows:
'Downloading project ‘7576e8f2-eaa2-4818-a643’ finished with an error: Project ‘myproject’ file ‘data.gpkg’: Network error. Failed to download file ‘data.gpkg’. System message:[HTTP/404] https://ourcloudserviceip/api/v1/packages/7476e8f2etc/late (see more in the QField error log).
The QField error log is empty.
I’m using QField 3.4.5 - Ebo (d260bb) on Android 13
I’m not sure whether this is an intended limitation to the QField app not being connected to ‘app.qfield.com’ by default or a mis-config of the docker image using the ‘docker-compose.override.local.yml’ instead of ‘production’ yml?.
Any suggestions would be helpful.
Imported from GitHub discussion by @shapley on 2024-11-18T11:40:50Z
Hey, shapley thanks for trying out QFieldCloud yourself.
I can assure you there is no limitation on self-hosted vs app.qfield.cloud and the problems you are experiencing are outside the QField app.
'Downloading project ‘7576e8f2-eaa2-4818-a643’ finished with an error: Project ‘myproject’ file ‘data.gpkg’: Network error. Failed to download file ‘data.gpkg’. System message:[HTTP/404] ourcloudserviceip/api/v1/packages/7476e8f2etc/late (see more in the QField error log).
If you get error HTTP 404, it seems a file with given name does not exist. Why I cannot say, needs deeper investigation. Seems there is a problem with the package, so check if jobs succeeded, the project table is updated with the latest package and the files are stored where they should be. I cannot guess much more, as there are quite a lot of combinations how you configured your system.
If you need dedicated support for your installation, please drop us a message salesqfield.cloud .
Imported from GitHub comment by @suricactus on 2024-11-18T13:47:42Z
It seems the ‘data.gpkg’ , ‘projectname_cloud_qfield.qgs’ and ‘projectname_cloud_qfield_attachments.zip’ won’t download as they were missing on upload to QFieldCloud. Will try and re-instate those files and report progress before closing call.
Imported from GitHub comment by @shapley on 2024-11-19T09:44:38Z
It was in fact the ‘data.gpkg’ from the list of files uploaded (in the Qfield projects Overview List) that were missing but where are they uploaded to on a self-hosted server?
Imported from GitHub comment by @shapley on 2024-11-19T09:48:31Z
Page not found (404)
May be the reason?
Imported from GitHub comment by @shapley on 2024-11-19T10:09:54Z
Just as a reference I’ve got these errors when trying to download the qgis project from any Android device. Anyone with any idea please let me know. I’m guessing there is an issue with the ‘.env’ config. As suggested by [suricactus] it could be anything.
Downloading project fccdaecd-4ec5-4719-b234-6bce0b78d0a9 finished with an error: Project projname, file data.gpkg: Network error. Failed to download file data.gpkg. System message: [HTTP/0]
https://my-ip-address/api/v1/packages/fccdaecd-4ec5-4719-b234-6bce0b78d0a9/late (see more in the QField error log)
Downloading project fccdaecd-4ec5-4719-b234-6bce0b78d0a9 finished with an error: Project projname, file project_cloud_qfield_attachments.zip: Network error. Failed to download file projname_cloud_qfield_attachments.zip. System message: [HTTP/0] https://my-ip-address/api/v1/packages/fccdaecd-4ec5-4719-b234-6bce0b78d0a9/late (see more in the QField error log)
Downloading project fccdaecd-4ec5-4719-b234-6bce0b78d0a9 finished with an error: Project projname, file projname_cloud_qfield.qgs: Network error. Failed to download file project_cloud_qfield.qgs. System message: [HTTP/404] https://my-ip-address/api/v1/packages/fccdaecd-4ec5-4719-b234-6bce0b78d0a9/la (see more in the QField error log)
Imported from GitHub comment by @shapley on 2024-11-20T11:17:36Z
