Photo Naming different save locations
Hello
I would like to know if i can store Pictures in differnet folders.
Currently i have about 12 folders with named pictures.
My goal would be too name the picture in the Qfield app via an Attribute.
And store in a specific Folder automatically.
this proves quite difficult for me.
I already tried to modify the code line in Qgis.
But i never programed a line…..
So if anybody could help me or give me a Tip.
the photo is an attribute attachement no table
so only 1 picture per objekt which is fine for me
the Code lines look like this currently.
‘streckenschieber/’ || Concat(‘name’, “BEMERKUNG”)
this is the default line
‘DCIM/wasserleitung_’ || format_date(now(),‘yyyyMMddhhmmsszzz’) || ‘.{extension}’
how do i need to change this so it works
the folder itself is in the same directory as the qfield project if i link them manualy it works just fine
but it would be great if i can take a pictue name it and store it in the right spot all at once
Hi Martin!
Here is the method I use (sorry for the interface in french!) :
1 : Keep the default path as DCIM is the form informations
2 : Use the field you want to set as folder with a / :
3 : Securise the formula with coalesce() and replace( , ‘ ‘,’_’). This will prevent the formula to collapse if the field is null.
Works for me (‘Faune’ is the value stored in “Couche”) :
Here is the formula if you want to past it :
replace(
‘DCIM/’
coalesce(“Couche”||‘/’,‘Autres/’)
format_date( “Heure”, ‘yyyyMMdd_HHmmss’)
coalesce(‘_‘||“Entite”,’‘)
coalesce(’_’||“Nom”,‘’)
‘.jpg’
, ’ ', ‘_’)
Hello Felix
I did try to copy the line you Posted but QGIS tells me there are a few probemls with the line.
Different Syntax errors.
I am sorry but this is something i cant fix, as stated i dont know anything about coding.
So an error like this is a total roadblock for me.
Thanks for your help, i will see if i can fix this.
But i have little hope :sweat_smile:
Heya!
I think it may simply be a formatting issue caused by quotation marks changing during copying and pasting.
Try it like this:
replace(
'DCIM/'
coalesce("Couche"||'/','Autres/')
format_date( "Heure", 'yyyyMMdd_HHmmss')
coalesce('_'||"Entite",'')
coalesce('_'||"Nom",'')
'.jpg'
, ' ', '_')
