Copying QGIS-projects to tablet/QField through QField Sync/USB-cable.
It seems like all projects names get the suffix _qfield added to their QGIS project filename, e.g apelsvoll.qgs ends up as apelsvoll**_qfield**.qgs in the export-folder.
This causes an error in my expression: aggregate(layer:=project_basename||'_skifte_f', aggregate:='max', expression:="skiftenr"||coalesce("del",null), filter:=intersects($geometry, geometry(parent)))
I have set polygon layer B within polygon layer A to inherit an attribute value set in polygon layer A. The polygon layer name starts withe the project’s base name. This works as a charm in QGIS without any hassle. I make it working in QField as well, but in that case I have to change the project name from apelsvoll_qfield.qgs to apelsvoll.qgs before copying the folder onto the tablet.
apelsvoll_forsok_f inherits the skiftenr-value 23a from apelsvoll_skifte_f in a QGIS-project called apelsvoll.
So, is there a way to change the default project filename when exporting? So far I haven’t find any way through the settings nor the preferences in QField Sync.
Using QGIS 3.26.3 and QField Sync 4.2.0.
Imported from GitHub discussion by @9ls1 on 2022-10-05T14:47:10Z
