I have points and tracks stored in a PostgreSQL database that I want to access from QField. When I set the layer to “Directly access data source” in QGIS, it still creates a .gpkg layer containing the current geometries.
Is there a way to have QField access my PostgreSQL server directly instead?
HI @ZahnKurt
It sounds like you are choosing the first option when converting your project into a cloud project. Try to use the SECOND option when creating your cloud project - read the details under each option and you will find that it indicates to use the second option, when working with Postgres
I do what you describe every day for many layers. Here is an example setting (the second applies, “cable packaging action”, since I do not go via QFieldCloud).
This works for me both on postGIS layers with geometry, or plain postgres tables.
If that does not work you, despite setting the options, I would guess there is an issue one level higher: double-check the basic map layer configuration to make sure it is really connected to postgres. In particular, check everything in the “Data Source Manager” ([Ctrl]+[L]).
