Using QGIS project with postgis db layers
I would like to know if when I create a QGIS project with postgis db layers in QFIELD Cloud, is it possible that these layers go to a postgis db stocked in QFIELD Cloud (like it does with QGIS Cloud) ?
The purpose is for people who will use these qgis project can read the data and are not blocked because of the company network who does not allow external network to connect to ours.
The last solution is to use shape. But it mean, we have to update the db data then export into shape then create a new QGIS project to put on QFIELD Cloud.
I tried to look in the doc or in the discussions but I did not find an answer to this (or i did not well read).
Thanks in advance for your answer.
Best regards,
Imported from GitHub discussion by @olivierlefl on 2023-03-09T15:55:16Z
