I’m using QField to record GPS tracks and measure how long each track took (effort time). I have start_dt and end_dt fields.
I was able to automate most of the attributes, but I’m having a problem with end_dt:
the time that gets stored is often the time of sync to QFieldCloud, not the time when tracking actually stopped.
This seems to happen because of “Apply default value on update”:
I need to enable “Apply default value on update” so that end_dt captures the exact time when tracking is stopped.
But when the data is later synced or edited, the default is applied again and end_dt is updated to the sync time, which breaks my tracking duration.
What I would like to achieve
start_dt
end_dt
Automatically set exactly when the user taps “Stop tracking”.
Never changed afterwards (not by edits, not by sync).
Duration
We work with Forest Guards who are not very familiar with technology, so we need this process to be as automatic and foolproof as possible, with no manual steps that can introduce human error.
Question:
Is there a way in QField to:
Tie end_dt to the “Stop tracking” event, and
Freeze that value so it is never changed again on sync or later edits?
If not, would it be possible to add such an option/feature?
Hi!
You can try only setting a new value when the field doesn’t already have one.
Assuming you are using now() to set your datetime, you can try something like this as your default value:
if ( is_empty_or_null( attribute(‘end_dt’) ), now(), attribute(‘end_dt’) )
This should only set a new date if the field is empty, otherwise set the existing date.
Hope this helps!
Thanks a lot for the suggestion — that makes sense and looks like it would prevent end_dt from being overwritten on later edits/sync.
Just to confirm: with this expression, do I still need to have “Apply default value on update” enabled for end_dt so it gets written at the moment I tap Stop tracking? Or will QField apply the default automatically on that stop event even without the “on update” setting?
I’m trying to ensure end_dt is captured once at stop-time, then never changes afterward.
yes, you still need to “Apply default value on update”
or, even better: if you make your timestamp field timezone-aware (field type: timestamptz) you will have no problems anymore and can use a simple expression like:
“beginn” + make_interval(seconds := m(end_point($geometry)))
(with “Apply default value on update” activated
hey @GeorgeJr809 did you get this to work? When I am using the expression @fggs-pascal provides the end_dt value becomes “now”
We encountered the same issue. When “Apply fedault value on update” is enabled the value is updated by pushing data to the cloud. In our case fields with now() shifted to other time zones or were simpled increased with a few hours.
Furthermore @cloud_useremail was changed to ‘root’ instead of the e-mail.
We solved this by adding two fields for Date:
- CREATED here “Apply fedault value on update” is disabled
- CHANGED here “Apply fedault value on update” is enabled and we added coalesce(string_to_array(@cloud_useremail,‘@’)[0],@user_account_name)<>‘root’ to the defauld value.
