Hi everyone,
I’m experiencing a synchronization issue between QField and QGIS after moving my project folder, and I’d really appreciate your help.
Context:
I created a QGIS project with a GeoPackage as main data source.
I exported the project using QFieldSync (“Package for QField”).
I collected data in the field using QField (edits + photos).
After that, I moved the entire project folder into a different directory (no internal changes, just a parent folder).
Problem:
When I try to synchronize back in QGIS using QFieldSync:
I get the warning:
“Original project not found… Would you like to use the currently opened project instead?” -
I select “Yes”.
The sync process completes without errors.
However:
The original GeoPackage (master file) shows the new data BUT is NOT updated and an icon with things that seems like plugs appear
In QGIS, it seems like I’m visualizing updated data, but they are not actually written into the main working GeoPackage.
Any insight or best practices would be extremely helpful. Thanks in advance!
