Synchronization project
hello to the community.
I wrote because I have a question.
I have a project which I work with colleagues who collected information in the field and when I wanted to synchronize the projects to obtain the final result, I observed that when I imported it, it only brought me project A and when I wanted to import project B it did not synchronize them, I only brought them separately.
I do not know if it happened to someone and can give me an idea.
I followed the step by step according to the Qfield document and testing in Qgis.
Clarifications: I wanted to synchronize according to the original project that people were given to collect information.
Imported from GitHub discussion by @ceciliaberon on 2021-12-29T20:00:14Z
Can you specify what are the QField, QGIS and QFieldSync versions? A sample subset of the project can help too or at least what type of data storage you use (GeoPackage, PostGIS?)
Imported from GitHub comment by @suricactus on 2021-12-31T00:05:16Z
ceciliaberon Marking as solved due to inactivity.
Imported from GitHub comment by @suricactus on 2022-03-09T07:19:51Z
Hello, sorry I hay not sean the message, I mandes to solve it, it was an
operational problem on me part.
El mié., 9 de marzo de 2022 04:20, Ivan Ivanov @.***>
escribió:
ceciliaberon https://github.com/ceciliaberon Marking as solved due to
inactivity.
https://github.com/opengisch/QField/discussions/2375#discussioncomment-2321949,
or unsubscribe
https://github.com/notifications/unsubscribe-auth/AMP5AVGVKLJZUF6QMTR4K4DU7BGKJANCNFSM5K6QKNYQ
Triage notifications on the go with GitHub Mobile for iOS
https://apps.apple.com/app/apple-store/id1477376905?ct=notification-email&mt=8&pt=524675
or Android
https://play.google.com/store/apps/details?id=com.github.android&referrer=utm_campaign%3Dnotification-email%26utm_medium%3Demail%26utm_source%3Dgithub.
You are receiving this because you were mentioned.
Message ID: <opengisch/QField/repo-discussions/2375/comments/2321949@
github.com>
Imported from GitHub comment by @ceciliaberon on 2022-03-09T10:38:51Z
