Save coordinates to shapefile
Hi, I would like to save the coordinates of the captured points in the attribute table. However, I can’t find any suitable variables that I can enter in the attribute form of the layer properties.
If I load the layer into my QGis project after data collection, the points are displayed correctly in the project. An “info” on one of these points shows me the coordinates in the “derived” area of the result window and not in the attribute table. However, the data should be written directly into the table of the layer during data collection. What am I doing wrong?
For the positioning a Leica Zeno FLX100 is used.
Thank’s for any help!
Imported from GitHub discussion by @Frontholz on 2022-06-07T09:18:57Z
Do it the same way you do it on QGis : on QGis, once you create a point on a layer, its coordinates aren’t saved in the attribute table…
You can use functions like this one for X coordinate, for example : 12.2. List of functions — QGIS Documentation documentation
Imported from GitHub comment by @VxTedxV on 2022-06-07T17:37:28Z
