Self-hosted QFieldCloud: best practice to manage organization-level secrets for all projects?
I’m currently running a self-hosted QFieldCloud instance (Docker setup) and I’m trying to understand the best way to manage secrets across multiple projects.
From the documentation, I understand that QFieldCloud supports organization-level secrets, which should be available to all projects as a fallback.
However, in a self-hosted setup:
  • I don’t see a way to manage secrets via the admin/UI
  • It’s unclear how organization-level secrets are supposed to be configured
  • I haven’t found clear examples for this use case
My goal
I would like to:
  • Define a default PostgreSQL connection (or pg_service) once
  • Make it available automatically to all projects
  • Avoid configuring secrets individually per project
What I tried
  • Looking for secrets configuration in Django admin → not available
  • Reviewing documentation → mostly refers to QFieldCloud SaaS
  • Considering configuring credentials directly in the QGIS Docker container (pg_service.conf, env vars, etc.)
My questions
  1. Is there a supported way to configure organization-level secrets in self-hosted QFieldCloud?
  2. Are these secrets expected to be set via:
    • database?
    • environment variables?
    • API only?
Any feedback or real-world setup examples would be greatly appreciated :slightly_smiling_face:
Thanks!
What QFC version are you on? I never used organization-level secrets, but we have a Secrets tab in the organization settings (I believe we are around version 26.3).
I have a similar problem. (I have the UI for adding secrets)
My goal is to have one secret configuration for an organization (I don’t want to add a secret for each of my user).
It works well when you assign a secret to an organization.
My project is also assign to an organization, but I want to open the project to a user which is not in my organization. When I try to do that I got this error :
Cannot add a user who is not a member of the organization as a project collaborator.
what is the best way to manage organization secret and have a project with multiple users / organization ?
Thank you
