Trimble GNSS receivers and QField
Hi everyone,
I would need some help for a surveying setup :
I have 1 trimble R8s (base), 1 trimble R2(mobile), 1 trimble R6(mobile), 1 trimble R4(base)
I’m using a base-mobile setup with corrections sent from the base to the mobile using radio.
I would like to be able to receive NMEA stream from my mobile rover to Qfield running on an android samsung tablet so that I could record new point with already corrected gnss positions. (Fix)
My tablet needs to stay connected to 4G network because I’m accessing remote postgis tables for my survey.
What’s the best way to do this? serial port? tcp? udp? (will tcp or udp work with the 4g connected to the internet?)
Please help!
Thanks a lot!
Imported from GitHub discussion by @dukytony on 2023-01-24T18:59:22Z
You will find the doc about GNSS positioning here Positioning GNSS
Hope you will find all your answers.
Best regards
Imported from GitHub comment by @lucienicolier on 2023-02-04T14:20:12Z
Has anyone here successfully used a Trimble receiver with QField and captured NMEA logs?
If you’ve done this, what connection method worked for you — serial (Bluetooth/USB), TCP, or UDP — and were you able to log the corrected positions directly in QField?
