Use QML forms in Qfield?
In relation to this issue (Feature request: geologic compass · Issue #1882 · opengisch/QField · GitHub), I’m actually prepared to try and see if I can teach myself enough QML to call QtSensors (that appear to be available in QField) and get a compass reading. I would then use this in an attribute form to populate the relevant attributes.
However, it is unclear to me whether QField actually supports user-defined QML widgets (the ones that are defined in the attribute form of QGIS) ? Quick and dirty tests using the “hello word” widget would appear to suggest otherwise, but I could not find an explicit answer ?
Imported from GitHub discussion by @jfmoyen on 2022-04-07T19:05:05Z
The short answer is “yes”, QField :green_heart: QML & HTML forms QField 💖 QML & HTML by nirvn · Pull Request #1221 · opengisch/QField · GitHub .
Imported from GitHub comment by @suricactus on 2022-04-18T07:30:58Z
It does ? Lovely ! My two-minute test suggested otherwise, but obviously I was too quick to give up :slight_smile:
Imported from GitHub comment by @jfmoyen on 2022-04-18T19:31:39Z
