Text and Spacer Widget
Hi everyone,
With QGIS 3.30, two new widgets were introduced to the ‘Attributes Form’ - a Text and a Spacer widget. I tried to implement them in a QFIELD project, but I don’t think they are supported at this point (this is also what the documentation shows). I know I can achieve similar results with an HTML widget, but I wonder if there are any plans to implement these two widgets. They are easier to use and might be a good and fast way to provide instructions in some data collection forms.
Imported from GitHub discussion by @Meykaefer on 2023-06-16T22:28:16Z
Hi I tested the text widget and it seems to work in QField on a device in case anyone else is wondering
Imported from GitHub comment by @jpnunn on 2024-09-09T13:22:29Z
FYI, this will be part of QField’s next release (circa mid-December). Test APK builds here available here: Implement feature form spacer widget support by nirvn · Pull Request #6759 · opengisch/QField · GitHub
