User Management QField Cloud
I managed to set up a QField Cloud Project with an PostgreSQL\Postgis DB on AWS RDS in the background. When creating a new GeoTable in QGIS an ID column is created and set as primary Key in the DB. In QGis 3.16 this field is filled automatically when adding a new feature in QField not. If I leave the field empty this geometry is not synced back probably because the ID is not uniqueä. I created the table then in pgAdmin and set the field as uuid an primary key. This fixed the issue.
Are there any better solutions?
The second main question: I wanted to share the project ONLY to one friend for testing. He has a QField Cloud account and I added him to my organisation. But I cloud not figure out how to share the project? Can someone help? Is there an manual online?
Best regards
Paul
Imported from GitHub discussion by @Phertl on 2022-02-16T20:43:04Z
After a little bit of try and error. I managed to share the project. Everything works very well. The changes can be applied in the QField Cloud Overview page.
Imported from GitHub comment by @Phertl on 2022-02-18T09:14:32Z
