Using spatial bookmarks in QField
I set a couple spatial bookmarks in my QGIS project. They show up correctly in QField search results and also in the map.
However sometimes the bookmark symbol is in the way. Is there a way to switch bookmarks to invisible inside QField or configure them in any way beforehand so they can be turned off?
Imported from GitHub discussion by @gdsrg on 2022-04-08T12:45:11Z
gdsrg , a new setting to toggle bookmarks on/off will be available in QField 2.1: Add a setting to disable display of bookmarks on the map by nirvn · Pull Request #2745 · opengisch/QField · GitHub
Imported from GitHub comment by @nirvn on 2022-04-14T10:17:21Z
