Value relation issue
Ever since I updated both QField and the Android Samsung tablet I’ve been having a value relation issue.
I have two layers: Station, Structure
The Station layer has a Field Station ID. I also like to record the Station ID in the Structure layer.
Previously I had this setup in the Structure Layer Attribute Form and it would work in QField:
But since the updates, I am unable to record a Station ID in the Station layer in QField. For some reason it is forcing a drop down (can’t text edit) that is completely empty.
When I test everything in QGIS it works with no issue.
I should probably set this up properly with a relation but this was a nice quick set up that, until now, worked.
EDIT: Stripped down project added
QField relation test.zip
I’m using a Samsung tablet, Android version 12. QField version 2.1.4 Bumblebee
Imported from GitHub discussion by @dragonfire151 on 2022-06-16T15:21:56Z
Feel free to attach a test project, that’ll increase chances of people looking at this.
Also, have you tried enabling the use completer checkbox?
Imported from GitHub comment by @nirvn on 2022-06-16T15:42:00Z
Added a stripped down project to the initial post.
I made some attempts with completer but ran into other issues.
Imported from GitHub comment by @dragonfire151 on 2022-06-16T16:51:29Z
This is what I get when trying your test project. I can see pre existing stations in the drop-down combobox and I can search for specific stations if I click on the magnification glass next to the combobox. I can’t see what’s broken in there, am I misunderstanding you?
Imported from GitHub comment by @nirvn on 2022-06-17T00:30:50Z
The problem is when you try to add a new station in the station layer. The structure layer works as desired.
Imported from GitHub comment by @dragonfire151 on 2022-06-17T12:21:48Z
dragonfire151 , can you attach a screencast please?
Imported from GitHub comment by @nirvn on 2022-06-17T12:25:41Z
When I bring up station and try to add a new one it shows a drop down with no data. Previously I was able to edit this field by adding text.
Imported from GitHub comment by @dragonfire151 on 2022-06-17T12:42:51Z
Imported from GitHub comment by @dragonfire151 on 2022-06-17T12:50:30Z
dragonfire151 , can you test the following beta APK: Bump vcpkg baseline by m-kuhn · Pull Request #2963 · opengisch/QField · GitHub
I think the problem has already been addressed during the 2.2 dev cycle.
Imported from GitHub comment by @nirvn on 2022-06-17T13:34:49Z
I tried out that download and still the same issue is occurring.
Imported from GitHub comment by @dragonfire151 on 2022-06-17T13:46:20Z
dragonfire151 , this is what I see:
Imported from GitHub comment by @nirvn on 2022-06-17T13:51:32Z
Yea that’s how it should be working. Oof ok. The last thing to update would be the version of QGIS I’m running and that requires getting IT involved because my workplace is ridiculous.
Thank you so much for your help!
Imported from GitHub comment by @dragonfire151 on 2022-06-17T14:09:58Z
dragonfire151 , I’m using the zipped project you attached above against latest QField dev. Unless you did not install the right APK, you should see the same Zip you attached working for you too. I don’t think you need to update QGIS.
Can you take a screenshot of the About QField panel (from the APK build you installed) and make a video of your issue? I’d like to rule out any lingering regression.
Imported from GitHub comment by @nirvn on 2022-06-17T14:14:40Z
https://user-images.githubusercontent.com/107634973/174320339-0c4b2182-4ee2-
4f90-a842-a1f7faea84da.mp4
Hope these help!
Imported from GitHub comment by @dragonfire151 on 2022-06-17T14:41:43Z
Well, you definitely got the right build, and the field is visibly not configured properly. I’m perplexed by this. What’s your device model?
Imported from GitHub comment by @nirvn on 2022-06-17T14:52:51Z
It’s a Samsung Galaxy Tab Active3
I too am very perplexed! We don’t use the devices through the winter so when gearing up for field work everything needed an update, the tablet, QField, and the QField plugin within QGIS. This caused a few headaches, like the new file location on the tablet for data transfer. But this is the last bug to fix.
I have a work around and have simply disabled entering the station information on the structure layer and changed the Station ID field on the Station layer to a simple text edit. But when presented with a problem like this it’s hard to not want to solve it.
Imported from GitHub comment by @dragonfire151 on 2022-06-17T15:03:37Z
dragonfire151 , when you were testing just now, were you using the same zipped project you attached to this discussion or something slightly different? One of the nice things you can do with QField 2.1 is downloading the zip file in your browser and open it with QField, it’ll auto import the project. Maybe try that here to rule out a slightly different project on your end?
Imported from GitHub comment by @nirvn on 2022-06-17T15:08:02Z
Wow. That worked.
Previously I had used the QField plugin in QGIS to make an exported project. I then copied that exported project folder to the tablet and that one was causing me issues. So the exporter in the plugin update must be off somehow. That makes sense since an older project I had exported via the QField plugin before the plugin update worked fine.
So I guess I’ll just zip everything from now on!
Thanks again for going through this process with me!
Imported from GitHub comment by @dragonfire151 on 2022-06-17T15:17:06Z
H. I am getting the same results using qfield 2.4.5 on a pixel 4a (and also samsung tablets). The first layer in QGIS that has a field set to “text edit” appears as expected in QGIS which allows for adding features but as a combo box in qfield without the ability to add new featuers. It only does this if other layers are set as value relations linking back to this layer and field. I have imported the project via a zip file and get these results.
Imported from GitHub comment by @jpnunn on 2022-11-14T13:40:49Z
Slight update - still not fixed though! I changed the field names so they were NOT the same as i thought this might be the cause. Now in QGIS it still work as expected (one text edit, one combobox), but in QFIELD both the fields in both layers are just text edit input, despite one being setup as a value relation field (so should be combobox).
Imported from GitHub comment by @jpnunn on 2022-11-14T14:11:34Z
