Value Relation works in QGIS but not in QField iOS 4.2.4
Hello everyone,
I am building a new QGIS/QField project from scratch.
Version QGIS 3.40.5, QField 4.2.4 (iOS), Latest QFieldSync
Project
One GeoPackage containing:
  • dtrn_kanten (Line layer)
  • dtrn_knoten (Point layer)
  • lut_fuehrungsform (No geometry table)
The lookup table contains two fields:
  • code (Integer)
  • bezeichnung (String)
The line layer contains:
  • fuehrungsform_code (Integer)
The attribute form uses a Value Relation:
  • Layer = lut_fuehrungsform
  • Key = code
  • Value = bezeichnung
In QGIS everything works correctly and the dropdown list is displayed.
I also created a Project Relation under Project → Properties → Relations.
I packaged the project with QFieldSync, copied it to my iPhone and opened the packaged project.
Problem: In QField the field is displayed as a numeric spinner (+/-) instead of a dropdown list.
Things I already tried:
  • recreated the project from scratch
  • recreated the GeoPackage
  • recreated the Value Relation
  • created a Project Relation
  • saved the project
  • packaged again with QFieldSync
  • deleted and reinstalled QField
The problem persists.
Is this a known issue on iOS or am I missing a required configuration?
@REBL , please add a sample project to help debugging your issue.
I uploaded it here, hope this works: Unique Download Link | WeTransfer
Not able to download your file anymore…
